cgz2
Message 1 of 8
Caller Display
Is this really a national fault? How long has this fault been known about? My caller display stopped working and I have had to reopen the BT fault 4 times now. Does anyone at BT know what is going on? Openreach have visited, changed sockets and still the problem remains unresolved. According to the latest chat with BT there is currently no solution but it is being worked on. No solution means no-one has had their caller display fault resolved. Is that true?
7 REPLIES 7
Message 2 of 8
Re: Caller Display
if you try a forum search you will find many posts on the subject
cgz2
Message 3 of 8
Re: Caller Display
I know there are many posts on this. Why does BT insist it is a fault with no solution yet it seems some on here have had their fault resolved?
Message 4 of 8
Re: Caller Display
it appears to be an intermittant problem and almost impossible to track down that is why you are being told it has no resolution yet
cgz2
Message 5 of 8
Re: Caller Display
If that's true then no-one, nationwide, has had their caller display fault fixed. Is that true?
Message 6 of 8
Re: Caller Display
the fault is intermittent some peoples caller display works without problems other have been resolved some still has problems there appears there is no standard cure
beans44
Newbie
Message 7 of 8
Re: Caller Display
You do realise if you have your caller display put back on you sign up for another one year contract!
Message 8 of 8
Re: Caller Display
Only if you want it free. If you are happy to pay the monthly charge, then your contract is not affected.
