Happiness
Message 1 of 9
Caller ID Not Working - Going around in circles
Please Help!!!!!
Caller ID suddenly stopped working circa 2 weeks ago. 8 Calls to BT, various agents, all  suggesting to stop & start the service package and yet still no result!!! Open Reach engineer came to the house, (No mask, no gloves, and no regard to safe distance), tried it and worked whilst he was here (the whole of 2 minutes)...and since then has stopped working again.
It's intermittent and on the odd occasions it shows the ID, but majority to nearly all other times just shows "External"
So fed up with going around in circles with BT and not getting anywhere. Open Reach engineer suggested its "BT's issue to solve"...
Please help as so much of my time has been wasted going around in circles
8 REPLIES 8
Matt-S
Moderator-Retired
Message 2 of 9
Re: Caller ID Not Working - Going around in circles
Hi @Happiness,
Welcome to the Community and thanks for taking the time to post.
I'm really sorry to hear about the problems you are experiencing with your caller display.
Have you tried another phone to rule out that the phone could be causing the fault?
While this question might not seem relevant do you have broadband on the line and if so is it fibre or copper?
Matt
Happiness
Message 3 of 9
Hi Matt- Yes, have tried different phones and still same issue!
I believe it's fiber broadband. Does that make a difference?
As said, when the OR engineer tried yesterday it worked, but now back to previous issue!
c
Matt-S
Moderator-Retired
Message 4 of 9
@Happiness,
Thanks for getting back to me so quickly.
We are going to need to take a look into this for you and we will case manage from here. I have sent you a private message letting you know the information we need from you.
Matt
Devon_Dave
Distinguished Guru
Message 5 of 9
Do you have other devices plugged into your phone line? If  you are using any plug in broadband filters they have been known to block the incoming caller display.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Happiness
Message 6 of 9
Hi Matt
I have sent you all the inforamtion you asked for - but have not heard anything and issue still remains!
CJT80
Recognised Expert
Message 7 of 9
@Happiness
It can take a while for the moderators to contact you back, however they will look into the situation and do their best to resolve it.  They are a small UK based team who will take ownership of the issue.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Veenay
Message 8 of 9
I have also just had similar issue - when you say "stop and start the service package" - did BT do this at their end?
Happiness
Message 9 of 9
Yes - but frankly it was a waste of time, and that's not where the issue lies
