George99
Message 1 of 8
Callers name not appearing on BT8600 even though listed in contacts
Recently my granddaughter's name has stopped appearing on the screen of our BT8600 phone. It used to appear and all other callers appear as normal if they are in our contact list. when she calls all that is displayed is the phone number. Obviously her name is entered in the contact list along with her number.
Has anyone any ideas why this has started to happen?
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: Callers name not appearing on BT8600 even though listed in contacts
Hi @George99  thanks for your post and are you still having this problem with the name not showing? If so check out the BT8600 help page and you will find the phone and email contact details for the help desk who will be best positioned to help you with this.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
George99
Message 3 of 8
I'll do that. Thanks John
Distinguished Guru
Message 4 of 8
Has she changed her number or now decides to withhold it.
Get her to ring you and after she hangs up dial 1471 and listen and check if that is the number she has.
You may get an announcement saying "we don't have the callers number" (or something similar)
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
George99
Message 5 of 8
Thanks for the comment Dave
Her mobile number is displayed on the screen correctly and we recognize it's her calling. However, although her name is entered in the contact list and her number is listed in the mobile section her name does not get displayed. All our other callers that call on a mobile are displayed with their name and mobile appearing on screen, not their number.
Andy005
Message 6 of 8
Have you tried deleting the contact and then adding it again? If that doesn't work then a reset of the base unit may be worth trying, the option should be in the Settings Menu but make a paper copy of all of your contacts first.
George99
Message 7 of 8
Thanks for your reply Andy
I have deleted and reinstalled the contact a couple of times. In the meantime I have received an email from the BT help desk telling me to reset the base which I will do.
George99
Message 8 of 8
Resetting the base unit solved the problem. Thanks for all the advice.
