zunaid
Newbie
Message 1 of 5
Can't make calls
Hi
I have just had BT line installed, was previously with Virgin, I am trying to make calls but when I dial a mobile or landline I get a dead tone, dialling the 0800 BT number did work but it it outside working hours at the moment, wondering if anyone can advise?
Thank you
Zunaid
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: Can't make calls
can you get incoming calls to your number? Have you got another phon you could plug in to try?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
lines_man
Message 3 of 5
Your numbers not been Imported yet.....
zunaid
Newbie
Message 4 of 5
Hi
Thanks for the replies guys.
I get the ringing tone on my mobile when I call the number but the home phone does not ring, unfortunately I don't have another phone to plug in. I'm not sure if it would ring if I plugged it back in the Virgin socket- did not want to try this in case it messed anything up!
How long does it take to import? He did it by around 6pm yesterday.
Thanks again
Zunaid
zunaid
Newbie
Message 5 of 5
Hi Guys
Just an update- this was resolved - it was the number being imported, Angelo in technical team was very helpful in resolving it.
Thanks again guys
Zunaid
