Message 1 of 2
Can you bar international calls from specific countries (USA and Australia). I get nuisance calls
from +1 (USA) and +61 (Australia) numbers. They never use the same number so BT Call Protect is almost of no use to me. I don't want to totally block all international calls, just USA and Australia. Thank you.
1 REPLY 1
Distinguished Expert
Message 2 of 2
Re: Can you bar international calls from specific countries (USA and Australia). I get nuisance call
BT Call Protect doesn’t have the option to bar calls from specific country codes. You would have to look at alternative blocking  systems.
However you may be wasting effort, as many nuisance calls are spoofed using voip systems, (or other), disguising the country of origin of the calls.
