AdrianH
Message 1 of 3
Cannot enter number into Personal Blacklist
What's wrong with the number below ?
The +44 is added automatically, so I have removed the leading 0 as if dialling from abroad.
It does't work with added whitespace either.
2 REPLIES 2
V_Meldrew
Recognised Expert
Message 2 of 3
Re: Cannot enter number into Personal Blacklist
Just a guess, the system might be looking for 11 digits as a verifier, by omitting it you are only entering 10 digits which is to short. Try entering the full number including the leading zero but leave out the +44
AdrianH
Message 3 of 3
Tried that, but as soon as you remove the +44, it switches to the country to USA. When you switch back to UK, it automatically adds the +44 and deletes whatever else is there.
I managed to add the number this morning by adding it from the received calls list.
