suejn
Newbie
Message 1 of 2
Concern 1400
Hi my handset is showing.... message full .....I have emptied everything and its still showing, and my base is showing FF, phone rings o.k. but answer machine doesn't cut in, any help would really be appreciated. thanks
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Concern 1400
have you check the user guide for the concero. suggest requires a system reset. it may default any outgoing message you set.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
