jaydog69
Message 1 of 2
Crackling on Outgoing Calls
Hi all,
When I make a call on my phone, it makes a crackling interference noise. Incoming calls don't have this noise on the line.
I have installed an ADSL faceplate but it still hasn't resolve the problem. The phone base unit is connected to the extension socket upstairs - it has to be as it interferes with my speakers if it's at the master!
Anything I can do? BT say there's no problem with the line.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Crackling on Outgoing Calls
Hi
Have you tried a known working corded telephone in the test point of your main telephone socket as shown below?NTE 5 Backplate.jpg
If you still get noise/ no dial tone here the fault is on the openreach cable and you will need to contact your Comms provider, if it is BT give them a call on 0800 800 151 (or 0330 123 4151 from a mobile)
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
