dweaver3481
Message 1 of 9
Damaged connection
pic1.pngHi all,
We have perfectly working broadband but a builder doing some work for us noticed the coloured wires going into the landline socket are mostly  detached. How is it still working?! More importantly I guess, will BT sort this if it inevitably perishes one day?!
Pics attempted to be attached.
Thanks in advance.
8 REPLIES 8
Message 2 of 9
Re: Damaged connection
you only need 2 of the wires connected but there are spare pairs in most cables hence why your broadband and phone still work  if broadband/phone stopped working then just phone ISP who will get openreach engineer appointment
Distinguished Guru
Message 3 of 9
Hi. As IMjolly says this is not a problem. Just open up the socket, poke the spare (green/brown) wires back inside the socket. Refix it back to the wall and forget about it
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
dweaver3481
Message 4 of 9
Thanks for the replies above.
I've just returned from holiday to a flashing purple light and no broadband. The diagnostic check found no issues. Could the wiring be the issue even though it has worked like this for ages? Any checks I can do?
Thanks.
Message 5 of 9
See if you get dial tone on your phone.
dweaver3481
Message 6 of 9
Just plugged phone in and I now get a he message"please check the line cord"
Moderator
Moderator
Message 7 of 9
@dweaver3481
Are you using a corded or cordless phone?
Sometimes you will get the message "please check the line cord" on a cordless phone if it's not picking up a dial tone.
It's best to test with a corded phone if you have one.
Matt
dweaver3481
Message 8 of 9
Cordless, unfortunately I don't have access to a corded one.
Moderator
Moderator
Message 9 of 9
Good chance that there is a fault on the landline. I will also send you a Private Message with details on how you can get in contact with the mod team however the private message may not be picked up until early next week.
It would be best to call 0800 800 151 and report the fault to get the ball rolling.
Matt
