Newbie
Message 1 of 13
Delete old blacklisted numbers on call protect
For God sake will some one make it simple to delete old blacklisted numbers. Limit reached at 100 and find it almost impossible to delete old numbers say from late 2018
12 REPLIES 12
Message 2 of 13
Re: Delete old blacklisted numbers on call protect
Log onto your MyBT then go to manage extras then "Manage BT Call Protect".  Go to the numbers you want to delete and select "Edit" then click on "Remove from blacklist". Click "remove".
If that doesn't work can you be more specific with what the problem is and what exactly happens when you try the above.
Newbie
Message 3 of 13
Done all that and find it when you select the old number to be deleted it jumps back to the top of the list (most recent blacklisted number) and then you have to scroll back down the list and hopefully find the number you were trying to delete. Would be better if at one stroke you could say select the whole month (for example say December 2018) and delete all numbers at the same time therefore releasing space for new number. PS history list only shows 2019 months
Message 4 of 13
When you finally select the number does it get deleted?
Newbie
Message 5 of 13
Yes but very slow to appear and confirm/save
Message 6 of 13
Unfortunately there is no option nor likely to be an option to delete the numbers en mass so I think you will just need to plod your way through your list.
Message 7 of 13
I'm not sure blacklisting has any point, scammers rarely use the same number more than once.
Message 8 of 13
I agree about using it for scammers is a waste of time but it does work for genuine "sales" companies who contact you.
Distinguished Guru
Distinguished Guru
Message 9 of 13
TPS should deal with those.
Message 10 of 13
Should but don't. Some don't bother about it.
