Message 1 of 2
Diverting overhead cable and removal of a pole
Hi
I have bought a property and plan to knock it down and build a new property on the plot.
Please can you put me in touch with someone to discuss disconnection, diverting and reconnecting the cable as well as removal of one of the telegraph poles.
1 REPLY 1
Message 2 of 2
Re: Diverting overhead cable and removal of a pole
@andyroberts1971
Its Openreach you need to contact.
https://www.openreach.com/network-services/altering-our-network
Quote
We can:
  • move, remove or relocate telegraph poles, manholes, joint boxes, green cabinets, underground ducts and overhead cables to accommodate your construction
  • do pre-demolition if you’re demolishing or redeveloping a property and our – or someone else’s – telecommunications equipment is in the way
  • remove internal wiring schemes
  • route overhead cable underground
  • survey and audit Openreach equipment affected by your project, protect them while you’re doing the work and reinstate them when you’re done
  • temporarily move overhead cables which are in the way of tree cutting or high vehicles
  • help with changing, moving and removing Openreach equipment to enable roadworks, bridge works and local regeneration
  • help with public transport infrastructure and additions and improvements to train, railway and cycle routes."
This is a BT Retail customer forum.
