KathB
Message 11 of 14
Re: Fault noisy
I finally managed to undo the screws to try the test socket and the crackling was just as bad. Does this mean the problem is not inside my property?
Message 12 of 14
Re: Fault noisy
correct it is outside your house you now need an engineer visit to fix the noise fault
KathB
Message 13 of 14
Re: Fault noisy
Engineer is already booked for Tuesday 21st. Thanks for the advice john46
KathB
Message 14 of 14
Re: Fault noisy
Fault traced to faulty underground cable as always suspected. EVERYTHING in my property has been checked now, thanks to the very thorough Openreach engineer. BT your online diagnostic checker is rubbish and obviously geared towards discouraging customers requesting a callout!!
