BaldEagle55
Message 1 of 5
Fax Set Up
Hello!
I am currently running a single BT phone line (with  BT Answer Machine) and BT broadband connection through an ADSL filter. How do I add a fax option on my phone line?
4 REPLIES 4
Guru
Message 2 of 5
Re: Fax Set Up
Your fax will run through your phone line so you need a phone splitter adapter.
Distinguished Guru
Message 3 of 5
Re: Fax Set Up
If you want the fax machine to answer when another fax calls you then you will need a fax switch.
This allows a phone and a fax machine to share the same phone line,
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
BaldEagle55
Message 4 of 5
Re: Fax Set Up
Many thanks. I do have a splitter, but maybe its not working, so I've ordered a new one on Amazon.
BaldEagle55
Message 5 of 5
Re: Fax Set Up
Many thanks. I will try the splitter first then look into your helpful suggestion. A quick look on Amazon brings up a very varied success rate with these, and they look expensive too!
