Do you mean
Newbie
Accepted Solution
Forgotten Pin
[ Edited ]
I 've forgotten the System PIN on my Verve 450, in fact, I don't remember having ever changed it.  The default 0000 doesn't work.
Does anyone know if it's possible to reset the pin back to the default?
TIA
Distinguished Guru
Re: Forgotten Pin
Hi
If you disable remote access it will reset the pin back to 0000.
http://btbusiness.custhelp.com/ci/fattach/get/223699/1232387075/redirect/1
page 52
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Newbie
Re: Forgotten Pin
Many thanks indeed
