ShadyCreek
Message 1 of 2
Forwarding calls to BT Mobile
I would dearly like to have any calls coming into my landline forwarded to my BT Mobile by default.  The only way I know of doing this would be to subscribe to an anytime call package (since 1000 minutes to BT Mobile are included and this would be more than adequate), as well as taking out a Call Diversion calling feature.
This all seems a little expensive.  Anyone know if there is a better solution?
1 REPLY 1
-Richie-
Expert
Message 2 of 2
Re: Forwarding calls to BT Mobile
Call diversion is the only way, you'd pay the diverted part of the call but you're right about anytime calls including 1000 minutes to residential BT mobiles.
You'd be looking at £9.99 for the anytime calls unless you get negotiate a discount and then £5.50 for call divert.
