Message 1 of 11
GPO box
Hi All,
Hoping you can help me on this.
My broadband and phone fine, haven't had any issues as such.
However we are getting a new door fitting and installation company won't do work due to the GPO junction box cover missing a wires showing and a few not connected. (please see pic attached) its on top of the door frame - I've tried to contact BT but with no help at all.
On the web chat the lady told me to just cut the wires if everything is working...
Question is can I just replace this myself ? is it a fire hazard with the wires not being connected?
10 REPLIES 10
Message 2 of 11
Re: GPO box
@mec9
Who provides your phone service?
Do not cut the wires, as you are likely to lose your phone line.
Message 3 of 11
Re: GPO box
@Keith_Beddoe Thanks for getting back to me.
BT are my providers
Message 4 of 11
Re: GPO box
is is BT that provides your broadband?
Message 5 of 11
Re: GPO box
Thats correct BT provides broadband
Message 6 of 11
Re: GPO box
Looking at that box, I would guess that is where your line comes in from outside, would that be the case?
If so, you will have to contact BT, and ask for an internal shift of the wiring. They will ask Openreach to do that, and there will be a charge.
Message 7 of 11
Re: GPO box
you could try local for a telecom engineer to move it and cheaper than openreach - and probably quicker
Message 8 of 11
Re: GPO box
yeah the line comes in from outside, if this was to get replaced with just another box do you know what type of box would be required? BT/Openreach will take too long to book in, front door is ready to be installed.
Message 9 of 11
Re: GPO box
probably 77a or 78a
Message 10 of 11
Re: GPO box
If there is only a single pair connected through, then a junction box is not needed, as the external and internal cable can be joined together using wire crimps.
Probably easier to get someone locally, as @imjolly  suggested.
