LadyQuake
Message 1 of 6
HOME PHONE DOES NOT WORK - INTERNET DOES
Hi
I do not get many phone calls, but someone tried today and got engaged tone.
I know it worked about a month ago as got new phones and tested them.
I tried calling it from mobile and also got engaged tone, and noone on it only me here.
I cant dial out also, I tried the test socket with a phone and no dial tone.
I tried troubleshooter page and today that page does not work, stops after the test bit and does not work any further.
Internet works and I am glad of that as need over Christmas periodbeing home.
On the check page I took the socket cover off and 2 wires are connected ok inside.
What could it be, can someone test the line from BT?
Regards
Shirl
5 REPLIES 5
Message 2 of 6
Re: HOME PHONE DOES NOT WORK - INTERNET DOES
you can carry out a line test at this link https://home.bt.com/login/loginform?TYPE=33554433&REALMOID=06-a3f89b6e-6f33-1058-ae2d-843babc40000&G... make sure you connect your phone to the test socket
LadyQuake
Message 3 of 6
Tried that again but when gets to test line bit the wheel goes round but that's all nothing else happens, left it half hour nothing.
Message 4 of 6
you can call faults from your mobile on
From a mobile: 0330 123 4151
adyjay69
Newbie
Message 5 of 6
I had yesterday when trying to test my line. I gave up and phoned them instead.
nick_london
Message 6 of 6
This is a fault at the exchange or at the cabinet in the street. If you dial your home phone number, it is likely it will appear as engaged. You must call BT on 0800800151 or 151 from a BT Payphone.
