Message 1 of 6
How can I change number of rings before 1571 diverts to answerphone
5 REPLIES 5
Expert
Message 2 of 6
Re: How can I change number of rings before 1571 diverts to answerphone
Distinguished Guru
Message 3 of 6
If you have the BT 1571 you can't if you have call minder you can.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Moderator
Moderator
Message 4 of 6
@MZRider welcome to the community and thanks for your posts as @Devon_Dave has mentioned this facility is not available on BT 1571 but if you have BT Call Minder you can adjust the number of rings. Call minder is a chargeable service costing £5.50 per month.
Newbie
Message 5 of 6
Hi,
I noticed your post was a couple of years old as I enabled 1571 for my mum, it is chargeable, I think 3.50 a month, does that mean I can now configure it to ring more times - she's not so fast on her feet these days!
Thanks in advance
Toddy
Tags (1)
Distinguished Guru
Distinguished Guru
Message 6 of 6
For the cost of a few months of 1571, you should be able to find a phone with an adjustable answering machine.
