Lm3
Newbie
Message 1 of 2
How to lock the keypad?
Can I lock the keypad on my cordless phone (BT essential phone)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: How to lock the keypad?
Hi @Lm3  Welcome to the forum and thanks for posting. I've moved your post to the most appropriate section to get help. The Essential Phone Y Nuisance Call Blocker help page has the user guide and if you can'y find the answer there you have the contact information for the product helpdesk.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
