Newbie
Message 1 of 9
I'm receiving lots of scam calls can I just pull the cable out of my phone for a month?
I'll only connect it if I need to make a call. Would that cause any problems?
Edit: I was told that the phone must stay connected to the network, or else I'll get in trouble with BT, or this will cause technical problems on the network. Is there any truth to this?
8 REPLIES 8
Message 2 of 9
Re: I'm receiving lots of scam calls can I just pull the cable out of my phone for a month?
Message 3 of 9
No problems whatsoever unless you're concerned about legitimate callers not being able to ring without an "appointment".
Newbie
Message 4 of 9
I've been told that the phone must stay connected to the network, or else I'll get in trouble with BT, or this will cause technical problems on the network. I guess that's not the case then?
Distinguished Guru
Distinguished Guru
Message 5 of 9
You've been fed BS.
Message 6 of 9
Absolutely not, will cause no problems whatsever.
Message 7 of 9
I haven't heard this before but if you're concerned you should get a definitive statement from BT.
Other posters in your position have unplugged their phones having discovered that nothing else absolutely guarantees a life free from scam calls on their landline; I've not seen mention of a BT compliance breach by doing so.
Message 8 of 9
There are many thousands if not hundreds of thousands of people who don't even have a landline phone let alone have one plugged into the socket. There is no requirement for you to plug one in if you don't want to.
It might however be worth plugging it in once a month and giving your land line number a call from another phone such as your mobile if you have one just to ensure that the circuit is kept "clear" and to check it is working OK in case you need to make an emergency call.
Distinguished Guru
Distinguished Guru
Message 9 of 9
You need a phone line to get BT broadband. Many people rely exclusively on mobile for phone calls though, and a good many of them won't keep a static phone plugged in.
EDIT: Snap!
