Newbie
Message 1 of 4
IP address compromised
Have just had a phone call from someone stating that they were from BT technical department (sounded like an Indian call centre) and that my IP address had been compromised as it was now a public IP address not a private one. Is this a scam and if so has anybody else had these calls.
3 REPLIES 3
Message 2 of 4
Re: IP address compromised
It's a well known scam, BT can't do anything to stop it.
If you report it here
https://www.productsandservices.bt.com/consumer/edw/scams/
 the number can be added to the Call Protect blacklist but it won't stop these scammers using another number.
Message 3 of 4
Like many others, I receive these types of calls on a fairly regular basis.
Another similar one is a recorded message, asking you to press '1' to get put through to an engineer (DON'T!).
Best thing to do with these is hang-up, block the number (if you have Call Protect), and report it to BT here:
https://www.bt.com/help/home/scams/
and Action Fraud here:
https://www.actionfraud.police.uk/report-phishing
Distinguished Guru
Message 4 of 4
Yep a complete scam, just ignore it or just humour them for a while. At least whilst you are doing that they are  not calling someone else
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
