squste
Newbie
Message 1 of 2
Incoming line socket
If I request the incoming line socket to be moved to a different position in the house, will the cable be run under floorboards to remain hidden? Or is the work done by running the line outside and into the house at a different point?
1 REPLY 1
iniltous
Recognised Expert
Message 2 of 2
Re: Incoming line socket
Depends what you actually mean, if your current line is overhead from a telegraph pole, then repositioning the master socket would be from the same pole, and ran around the property to enter CP's to where you want the new socket positioned, if your service is underground, where it entered the property would stay the same , and a surface mounted cable ran to the position where you want the new socket...nothing would be put 'under the floorboards'
