Newbie
Message 1 of 2
Internet connection
Had an automated call from BT?? This morning mentioning faults with Internet then it said my Internet would be terminated and to stay on the line if I wanted to talk to someone but then it just said goodbye and line went dead. Internet is currently working. I'm in the KA26 area of Ayrshire.
Has anyone else had this message?
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Internet connection
Many, as a search of this forum will reveal. It's a scam. Why would BT or anyone else use an automated call to contact you about an internet fault you've not detected yourself? If you get another which doesn't cut itself off just hang up, telling the caller to go away with whatever phrase comes to mind.
