Newbie
Message 1 of 5
Is this my master socket
As the title says is this my master socket? The reason for asking is we have just bought a 3rd floor flat and didnt know if BT can move the master socket (if this is it) into the bedroom where there is what i believe is an extension?
Appreicate any advice or replys
Lewis
4 REPLIES 4
Message 2 of 5
Re: Is this my master socket
That looks like NTE5 master socket. It is an easy job to swap your master and extension. Get telecom engineer from local paper
Newbie
Message 3 of 5
Many thanks for the prompt reply!
Would it mean running extra cables?
Thanks once again
Message 4 of 5
No. Engineer would make use if the existing cable
Newbie
Message 5 of 5
Thats great many thanks for your help
Lewis
