austin1
Message 1 of 6
LINE-OUT ON BT6500
I am unable to get a line-out on my BT6500 Cordless Digital, which has three hand-sets, including the base hand-set. When I press the relevant line out button I get no dialling code and the message: "Call already in progress, Join Call?, Yes/No? I get no further when I press either "Yes" or "No". I can receive incomig calls. All the relevant lighrs function.  I have not changed the batteries, which appear to be charged. I woiuld be grateful for advice on how ti proceed.        I
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: LINE-OUT ON BT6500
Remove the power to the base station unit, wait 30 seconds, then plug it back in.
pompey1898
Recognised Expert
Message 3 of 6
Are you sure that another handset has not cleared down ?  That is when I get the message you quote.
Devon_Dave
Distinguished Guru
Message 4 of 6
Suggest you unplug the base station from the phone socket and try a corded telephone and check that you have a dialtone.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
austin1
Message 5 of 6
Hi Keith-Beddoe, Pompey 1898.Devon Dave'
Many thanks. Having followed your advice, I have solved the issue.
Austin1
Devon_Dave
Distinguished Guru
Message 6 of 6
Hi. In case others have a similar issue how did you solve the problem?
