michelle7
Newbie
Message 1 of 3
Landline/fault Tracker problem
My mum's landline has been down for 24 hours. I went through the fault checker it said a fault has been found outside the home and that it would be fixed before the 16th. I'm concerned as suddenly on the fault tracker it says there are no faults to display for this account!!
My mum is a pensioner who has been waiting for an important call which she's probably already missed.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Landline/fault Tracker problem
Hi @michelle7,
Welcome to the Community and thank you for posting.
I'm sorry your mom has a fault with her service. If you send me in your details, I'll be able to take a look at what is happening with the fault.
I have sent you a private message with instructions on how to contact me. You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
michelle7
Newbie
Message 3 of 3
Thank you, the problem seems to have been resolved now.
