Message 1 of 4
Landline went down Openreach engineer checked roadside cabinet but didn't phone the line to property
Third Openreach engineer visited the property and checked the line feed to find a line spike in a BT underground distribution 63metres away, this way caused by corrosion of cable wire and repaired by 4th engineer.
3 REPLIES 3
Message 2 of 4
Re: Landline went down Openreach engineer checked roadside cabinet but didn't phone the line to prop
Thanks for info. 👍
Message 3 of 4
Are you telling us what happened or are you looking for further advice?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
I was providing the story and how inefficient the Openreach process was in the beginning
