Message 1 of 2
Line crackle possible causes - Broadband disconnecting
Hi,
I have had an ongoing problem for quite some time now - potentially a year or so.
I am currently on a G.fast product. Occasionally, perhaps a couple of times a month my broadband just goes down and stays down. If I check the landline by dialling 1471 I hear crackling on the line (via my Gigaset N300A IP base station)
If I wiggle the BT socket end of the phone cable the crackling stops and my broadband modem can once again sync. All is well for a few weeks and then the same thing happens again.
This happened also happened prior to the G.fast upgrade so can't put it down to that.
What I have tried so far:
  • New Gigaset base station and cable
  • New Master socket and G.fast face plate (BT engineer fitted when upgraded to g.fast)
  • New cable from phone to socket (different brand)
Nothing seems to prevent the crackle from returning every few weeks and I just don't understand why.
Why is it that just wiggling the wire can fix it instantly but no amount of new cables or sockets is fixing the issue. I keep thinking there must be some kind of bad connection between me and the cabinet but again, why does it resolve instantly and last a couple of weeks just with a wiggle of the wire.
Perhaps it's just a feature of the Gigaset base, but I see no-one else complaining about this. I'm a bit stumped.
1 REPLY 1
Message 2 of 2
Re: Line crackle possible causes - Broadband disconnecting
The most basic test is using a corded phone in the test socket and then dial 17070 option 2. Should be completely silent   Any noise needs to be reports to 151
