philharve
Message 21 of 26
Re: Line fault, intermittent Ring Trip!
Hi All
A busy life has meant I have not been able to progress this issue as fast as I would have liked but it is critical that a fix is found quickly. I am a step closer this evening because I have achieved success, of a kind.
There was one test I should have done but omitted. I previously reported that with ONLY my old cable telephone plugged in to the Master Socket, my landline worked OK. This evening I plugged in ONLY my BT 3550 network (base station + 3 wireless handsets) and it worked OK. With BOTH cabled 'phone and '3550 plugged in, my system goes dead, yet they have coexisted happily together for the last 7 months with no changes to my system. Broadband has always worked.
This afternoon I received a call from TalkTalk Customer Care and I gave them a full progress report. The agent said he would leave this case 'open'. I feel there is still a mystery but at least I can now be reached again by landline. I have abandoned the cable telephone for now.
I thought members might like to see my home telephone network and I have attached a JPEG schematic showing its configuration. The extension booster used to work with 3 cabled telephones upstairs but I now have just 2 wireless phones upstairs.
Regards
Phil
Distinguished Guru
Message 22 of 26
Is your service with BT or talk talk?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
philharve
Message 23 of 26
I pay TalkTalk but all my equipment is BT & line is owned by OpenReach.
There is still the mystery as to why I cannot use my cable phone and 3550 together when they happily coexisted previously for 7 months. I am wondering if REN has decreased? We've had a lot of rain and flooding. Grasping at straws? Yes!
Regards
Phil
Distinguished Guru
Message 24 of 26
Ok. It's just that this forum is for BT consumers. Sounds like you are a talk talk customer.
philharve
Message 25 of 26
It was this suggestion that led to a solution but the underlying cause remains unknown.
philharve
Message 26 of 26
I chose to raise the issue with the BTCare Community Forum because all my equiment is BT and the problem is of a technical nature. I encounter Openreach engineers moreorless every day but I have yet to meet a TalkTalk engineer, if they exist. I doubt very much they would have the knowledge and experience of an Openreach engineer. Being ex-BT myself I know who I trust.
If a solution was found it is highly likely that another BT customer, with a siilar problem, would stumble upon this thread and hopefully help them solve their particular problem.
I have given you credit for suggesting the swapping of the corded phone with the base station. I had it in mind to do that anyway but I sensed you and I were thinking alike and I'm always willing to try out a helpful suggestion.
I regard this problem as solved and hope that another BTCare member will provide the answer to the question uppermost in my mind. I still believe there maybe an exchange or cable fault but I will take that up with TalkTalk when they next call. If I can convince them I'm correct it will be Openreach that takes the credit.
Regards
Phil
