Mobee
Message 1 of 7
Line installation
Have waited 9 months for openreach to connect cable in new house without reason.   Complaint passed to case management 3 months ago who can do nothing to solve it.   They keep escalating problem with openreach every Tuesday with no result.    What can I do.
6 REPLIES 6
Message 2 of 7
Re: Line installation
Hi @Mobee
Who is “They”?
Mobee
Message 3 of 7
BT
Message 4 of 7
Was/is this a new build that you are trying to get connected. Are you a BT customer
Mobee
Message 5 of 7
Yes new house and yes BT customer.
Moderator
Moderator
Message 6 of 7
Hi @Mobee,
Welcome to the Community and thank you for posting. I can understand your frustration and I'm sorry your order has been delayed.
If you're looking to set up service at a new build address, the order can be delayed if there is any ducting or cabling work needed. If you like, I can take a look at what is happening with your order.
I have sent you a private message with instructions on how to contact me. You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
PaddyB
Moderator
Moderator
Message 7 of 7
Hi @Mobee,
Once again sorry for the delay in getting your service connected however I'm really glad to hear that everything is now up and working.
Matt
