rl1212
Newbie
Message 1 of 2
Low hanging phone cables
Hello, I’ve found myself in a bit of a odd situation with two overhead phonelines. In fact they’re so low the phrase ‘head height’ phonelines would be more appropriate! I have two cables running from the pole on the pavement outside my house that stretch the entire length of my plot (approx 25m). They then rest on the boundary hedge and then go up onto the neigbours’ Houses behind, another 10&20m respectively. The cables are not my line, nor are they in a public space posing a hazard so I’m struggling to find out how to get them tightened. Is there a way to report this or some sort of routine maintenance by by/openreach that would pick this up and fix it? Thanks, RL
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Low hanging phone cables
@rl1212 Thanks for posting, you can report this directly to Openreach on this number  0800 023 2023 (option 1)
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
