Archie_
Message 1 of 5
MK4 phone socket to telephone extension socket
Hi,
I'm looking to run a telephone only extension from the phone socket of my MK4 plate on the master socket, to a slave socket in the hall.
I intend to use two pair cable, one end wired to a 431A going into the MK4 and another into the IDC connectors in the slave socket in the hall.
Will there be any problem with this?
I thought the wires might 'crossover' seeing as how I'm going from an output socket to IDC and then output again, which might cause issues when I plug the phone into the extension socket in the hall.
I am aware I could run an extension from the IDC in the master, but I want to try and minimise any possible interference.
Cheers,
A
Tags (2)
4 REPLIES 4
Message 2 of 5
Re: MK4 phone socket to telephone extension socket
There is no 'crossover' with telephony as it is only 2 wires which are not polarity conscious in any case. It would be much simpler just to connect the extension to IDC connectors 2&5 in the master faceplate as is their intended use, you are just adding another fault liability point by using the 431.
Archie_
Message 3 of 5
Thanks, but would that not possibly interfere with the signal from the master socket as I understand when testing the line extensions are decoupled to prevent possible interference?
Message 4 of 5
wired correctly it should not interfere with your broadband connection and is way vast majority are connected without problem
Message 5 of 5
Line extensions are decoupled for fault finding purposes to eliminate problems with your internal wiring.
Your electrical connection will be exactly the same whether you use a 431 or wire directly, both will be disconnected by removing the faceplate on the master. Connecting via a 431 is just adding another source of failure.
