Lukas1
Message 1 of 8
Master socket wiring problem
I've had a bit of a nightmare whilst removing wallpaper in my hall. I took down some cabling which I then managed to trip over. It turns out, it's come right out of the master socket. I have 4 coloured wires blue, orange, green and brown and 3 connection points, marked as 2, 3 & 5. Please see photo. Would anyone be able to advice which colour connects where? The master socket is a BT Openreach MK2. Many Thanks in advance.
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: Master socket wiring problem
@Lukas1
Who provides your phone service?
licquorice
Message 3 of 8
Probably blue and orange in 2&5, doesn't matter which way round.
Lukas1
Message 4 of 8
It's my father's house. I believe it's BT.
licquorice
Message 5 of 8
It will be pins 2&5 regardless, nothing in 3
imjolly
Message 6 of 8
that cable is not the incoming so must be going to an extension outlet in the home  check the extension and see which wires are connected to 2&5 and then do same at master
Lukas1
Message 7 of 8
I've found the extension on the second floor which seems to confirm blue 2, orange 5 but it doesn't seem to get the internet running again as I've now tried it several times.
licquorice
Message 8 of 8
If all you have done is pulled the wires out from the socket, replacing them in 2&5 should restore service. Are you sure you have pushed the wires fully home, did you use a proper tool or the blade of a screwdriver? If the latter, have you splayed the contacts so they are no longer displacing the insulation and making good contact with the wire. Do you get dial tone at the socket?
