Message 1 of 12
Master sovket
Am trying to put my phone socket back together, I have 4 wires available - black, orange, white and green. I have a new mk socket, previous one was destroyed. On rear of socket are the numbers 1 to 6, which wires connect to the numbers
11 REPLIES 11
Message 2 of 12
Re: Master sovket
Welcome to this user forum.
Who provides your phone service?
Message 3 of 12
Re: Master sovket
Thanks for amazingly quick reply - its BT
Message 4 of 12
Re: Master sovket
What does your master phone socket look like?
Master socket with one socket
Or
Master socket with two sockets
Message 5 of 12
Re: Master sovket
The broken one((i've just found it) has adsl v1.0 on the front, i dont have any extensions around the house anymore, i have bought a single socke from bnq it has no markings on it just the makers MK
Message 6 of 12
Re: Master sovket
The bottom left resembles my old broken one
Message 7 of 12
Re: Master sovket
@Eankirk wrote:
The broken one((i've just found it) has adsl v1.0 on the front, i don't have any extensions around the house anymore, i have bought a single socket from bnq it has no markings on it just the makers MK
Then its probably the wrong type, as it needs to be a master socket with the extra components inside.  It must have that extra component in it, plus a resistor and lightning protector.
The correct replacement would be an NTE5C with a MK4 faceplate as shown here.
https://www.openreach.co.uk/orpg/home/helpandsupport/how-toguides/howtoguides/downloads/NTE5C_Instru...
Message 8 of 12
Re: Master sovket
Aaaah, so if i buy a socket as pictured it will work?
Message 9 of 12
Re: Master sovket
The direct replacement for your broken one, is described on my last post.
Look at the part about the MK4 filter, on that document.
You can buy the whole unit for about £15.
Message 10 of 12
Re: Master sovket
Thank you:) Sorry to be a pain i have followed the link and read everything i think, my wires are black, orange, white and green i cant see this combination in the article, are my wires out of date?
