@Dippydolly
You would have to ask BT to arrange an internal shift of the master socket. This would be done by Openreach, and there would be a charge.
It would be cheaper to run your own extension cable, run an Ethernet cable, or use a couple of broadband extenders.
An internal extension cable would not have any impact on the connection speed, provided its run directly from the master socket.
