Keythie
Message 1 of 6
New BT Converse 2300
Hi Ladies & Gents
I have a new BT Converse 2300 plugged into a line which has caller display enabled.  The phone replaces a Paragon 650 which was showing caller numbers when people called me, but the converse just displays NO CALLER INFO.
How do I enable caller display on this phone?
Also when on a call, if I push the secrecy button, nothing happens.
Any help offered is much appreciated thanks!
Br
Keith
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: New BT Converse 2300
hi. have tried dialling *#234# from your home number and listen to the announcement?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Keythie
Message 3 of 6
The message says "The number you have dialled has not been recognised"
I got to the bottom of the caller display problem.  My ADSL filter wasnt working correctly, I swapped for a new one and caller display now works.
BUT
The other keys still dont work .... HANDSFREE, SECRECY, and any stored numbers dial with a prefix 0000 !
Keythie
Message 4 of 6
BT Converse 2300
Does anybody know why stored numbers in a BT Converse 2300 would dial with a preix 0000 ?
Stored number 0123456789 appears like that on the setup screen but dials 00000123456789
Message 5 of 6
Re: BT Converse 2300
Maybe it simply displays the maximum number of possible digits?
If it actually dialled those zeros, your call would not connect.
Keythie
Message 6 of 6
Thanks for your reply.
The phone does dial those digits and says, "number not recognised, please hang up"
