shoalshook
Newbie
Message 1 of 2
No BT Mobile signal
I have BT Total Broadband, including mobile phones (HTC). However we do not get a BT mobile phone signal inside or outside the house. Is there a way of using my broadband to boost phone signal so that I can use the mobile at home?
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: No BT Mobile signal
Hi
Do you want to use it for broadband or for making voice calls?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
