Message 1 of 8
No Incoming or Outgoing Calls on my phone
I have a BT phone and Broadband. I don't receive many calls but for the last couple of days the phone would ring, but wouldn't connect me to the caller. Today I tried to make a call and the same thing happened, I couldn't connect to the caller. I've got a broadband signal so it's the landline that has the fault. Before I make a official complaint, is there anything I could do.
7 REPLIES 7
Message 2 of 8
Re: No Incoming or Outgoing Calls on my phone
Welcome to this user forum.
You need to try another phone if possible.
Also try connecting the phone to the test socket, to see if you can get dial tone there.
Message 3 of 8
did you try a different phone to eliminate a phone problem
did you try using the test socket with new filter to eliminate your internal wiring
if tried bothe and still same then just report a phone fault to 151 - no complaint just need engineer visit
Message 4 of 8
I'll have to use the BT app to report fault as my line is dead on this phone.
Message 5 of 8
Or you can call 0800 800 151 on a mobile phone.
Message 6 of 8
All sorted. Engineer came out and put the latest junction box on the wall, then he disconnected two other sockets in the house as my phones are wifi and I wasn't using these boxes anyway.
Message 7 of 8
You will probably charged for that.
http://bt.custhelp.com/app/answers/detail/a_id/12439/~/engineer-home-improvement-service-charges
Message 8 of 8
Might be, but I had phoned 151 hours earlier to cancel and told the engineer this when he turned up, but he said that he would check things for me. So my cancellation call to Cardiff is on tape somewhere.
