spencerz
Message 1 of 3
No Master socket only 52A junction Box ?
Hi
Ive just moved house and signed up with BT for phone and infinity package (FTTC), Problem is there is no master socket ! The wire comes into the house to what I think is a 52A junction box and that is where it ends.
Will the engineer (who is coming at the end of this month) carry a master socket with him or would this put a spanner in the works ?
I only need the one socket so Id have thought it should be straight foward.?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: No Master socket only 52A junction Box ?
Yes, as long as an engineer visits he would fit a linebox, obviously as there is no socket in the house (previous tenant removed it? I guess you would have to pay the full price for a line install.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
spencerz
Message 3 of 3
As im new to BT the £130.00 connection fee is incuded in the package so I guess the new socket will cost nothing.
Thanks.
