grannyand
Message 1 of 5
No dial tone one one of two handsets BT8600
I have BT8600 with two handsets.
Both have worked perfectly until recently.
Now one of the handsets has no dial tone.  Also when someone phones me, on that handset I can't hear the  caller.  Everything else on it works fine.
The other handset still works perfectly.
Is there anything I can do, or is the handset kaput?
4 REPLIES 4
V_Meldrew
Recognised Expert
Message 2 of 5
Re: No dial tone one one of two handsets BT8600
Sounds like the earpiece is defective, can you hear anything from that phone in handsfree mode
Message 3 of 5
Its worth taking the batteries out for a couple of minutes, and then putting them back in, just in case the internal hardware has locked up.
grannyand
Message 4 of 5
The battery solution worked.
Many thanks!  I'm glad it was so simple.
Message 5 of 5
Excellent 😀
Its often something simple.
