Moderator
Moderator
Message 11 of 18
Re: Nuisance calls
Hi @davidmhollander,
Which calling features do you currently have on your account?
Cheers
David
Message 12 of 18
Re: Nuisance calls
Number I D. Plus the 1571 blocking feature included by BT
Message 13 of 18
Re: Nuisance calls
I'm sorry. I don't know what this means.
Message 14 of 18
Re: Nuisance calls
Number ID is when it displays the callers number on your phone. The 1571 thing is BT call protect where you can set a list of blocked numbers using the BT website and logging in to your account.
Recognised Expert
Message 15 of 18
Re: Nuisance calls
1571 is the messaging service.  Bt Call Prtect is 1572.
Message 16 of 18
Re: Nuisance calls
Yep, thanks for taking the time to reply but I’m not really sure what your point is.
Message 17 of 18
Re: Nuisance calls
For goodness sake...I got an email saying that this above comment was in response to my message which it wasn’t. I wasn’t shown the new messagaes until after I had posted a reply. Again typical BT rubbish. So I end up writing a message which is nonsense. My apologies for my part, more hate vibes to BT for theirs.
Message 18 of 18
Re: Nuisance calls
  • Yep you are quite correct. My mistake...
