razlan23
Newbie
Message 1 of 3
Openreach bt master socket 5c
Hi,
My broadband and phone line have not worked for about 2 weeks now and I thought it was initially my broadband provider, however, I’ve tried with several phones now and using the test socket, there seems to be no line and nothing is currently working. I have just changed my WiFi provider and it will activate this coming week but I don’t think it will work as I think it may be the master socket connection itself that isn’t working. Could someone help please?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Openreach bt master socket 5c
If you don't have a dial tone when you plug a known working corded phone into the test socket then you have a fault external to your premises. You need to report this to your line provider.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Moderator
Moderator
Message 3 of 3
@razlan23 who do you pay your line rental too?
