booniitee
Newbie
Message 1 of 6
Option to port landline number
I ordered a broadband package online two days ago, and it included landline, switching both from Sky. It had only just occured to me that I was not asked whether I want to keep my landline number, nor was there an option to do so.
Looking it up on the BT website, it merely says that:
> You can normally keep your phone number too. We’ll let you know when you order.
Is this done automatically? I very much would like to keep my landline number (and I am not changing address).
Distinguished Guru
Message 2 of 6
Re: Option to port landline number
Unless you have the person your current number and requested the number port , it would not normally happen automatically
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 6
@booniitee
Who was your landline originally with before you moved to Sky?
Have you moved house since you were given that first number?
Communityhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
booniitee
Newbie
Message 4 of 6
Apparently, my dad, who is paying for the broadband and landline, had received an email about the number being unchanged, which I assume then had occured automatically. I was not aware of this when I made this thread, apologies for misinformation and the bother.
For future reference, say if I want to move back to Sky, how do I determine what I need to do?
@Keith_Beddoewrote:
@booniitee
I believe we took over the same number when we had moved in, well over 15 years ago. It was with BT back then. We switched to Sky at some point, and now going back to BT again. However, there seems to be a Telewest socket next to the Openreach one, so the number may well have came from them originally, but I have no way to confirm.
Message 5 of 6
@Keith_Beddoewrote:
@booniitee
If the number you have now, is the same as when you were with BT Retail, then that number will belong to BT Retail, and will exist on the equipment in the same local BT Retail exchange.
Provide you are now living at the same address, or at an address which is still within the area that that same physical exchange serves, then you should be able to keep your number.
Is that the case?
Message 6 of 6
If you wanted to move back to Sky sometime in the future, then it should be possible to keep your number.
The problem with number retention occurs if people try to port a number twice, and the number does not belong to either of the providers. It will revert to the number range holder.
