Roy5
Message 1 of 8
Phone fault
Reported a phone fault online on 17 December.
Heard nothing.
Tracking fault it says it's been completed but no one has contacted me. I have a new fault number now.
no dial tone
checked with two phones no dialtone
checked test socket no dial tone
tried chat keep getting cut off. Phone line no good as cost too much on mobile.
any help would be much appreciated. Thanks.
7 REPLIES 7
Distinguished Guru
Message 2 of 8
Re: Phone fault
Hi. I have requested the help of a moderator for you.
I assume your line provider is BT Retail/consumer?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Roy5
Message 3 of 8
Re: Phone fault
Yes my line provider is BT.
Moderator
Moderator
Message 4 of 8
Re: Phone fault
Hi @Roy5,
I am sorry to hear that your fault is ongoing. You can call our help desk on 0800800150 and ask for our faults department. 0800 numbers should be free to dial from UK mobile phones within the UK.
To get in touch with us, click on my user name, view profile, and then copy and paste the link under "Moderation Team Email Address" into your browser.  Complete that form and we'll get back in touch with you. It may take us 1-2 working days before we can get back to you.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
Community Manager
Community Manager
Message 5 of 8
Re: Phone fault
Hi @Roy5 thanks for sending in your details, I am sorry for all the problems you've had in getting this sorted.
I was able to pick up a fault on my end so I have sent this to our suppliers. It might them a few days to update us but I'll get back to you as soon as I can.
Community ModeratorStephanie
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Community Manager
Community Manager
Message 6 of 8
Re: Phone fault
Hi @Roy5 I called and left a message. The engineer was able to find a fault and going by his report the fault has been fixed.
Could you get back to me either here on by replying to my email, and if there's still a problem I'll get it investigated further?
Kudos”
Roy5
Message 7 of 8
Re: Phone fault
Hi Stephanie
Thank you for your help. The phone line is now working.
Roy
Community Manager
Community Manager
Message 8 of 8
Re: Phone fault
Thanks for confirming that @Roy5, I'll send you an email shortly with some additional information but please do post back if there's anything else we can help with in the future 🙂
Kudos”
