Message 11 of 12
Re: Phone lines across my property
You can ask them using this form. They should be able to give you an estimate of the costs involved.
http://www.openreach.co.uk/orpg/home/submitFeedback.do?contactReason=remove_relocate_external_networ...
Distinguished Guru
Message 12 of 12
@k3hys2377 wrote:
Hi, Ive just seen your post, I have a major cable that joins two posts that runs ove my proerpty, I am about to buld a 2 story side extension but this cable is in the way!! this cable is more then 3m from the ground but is just under 2m from the corner of my house... could get openreach to move this foc?
Free of charge is hardly likely.
toekneem
(EASBF)
