Message 11 of 20
Re: Phone not working
@imjolly @Keith_Beddoe
Tried all 4 spare splitters, smart hub restarts for each but still the phone gives a message on the screen to check the phone line.
Looking for some suggestions, please.
Message 12 of 20
@Carlusha
Check with a phone at the test socket, if it does not work, the you will have to contact BT and report a phone fault.
Its possible that Openreach have forgotten to connect up the exchange side of the cabinet.
Message 13 of 20
Thanks, will do
Message 14 of 20
@Keith_Beddoe @imjolly
I have carried out the test advised by you and can confirm there is no phone line (although broadband is fine).
Kellys carried out the installation in our flat and in the building's main cabinet in the basement (60 flats here). Presumably Openreach are responsible for the exchange side of things as one of you mentioned.
We were transferring our existing number from the old place to our current place so some adjustment would have had to be made, though in the same exchange (we only moved 350 yards up the road).
As I am deaf and my wife's mother tongue is not English, would one of you be kind enough to report this a one of the Mods for action?
Message 15 of 20
@Carlusha
You can report the phone fault online.
https://support.bt.com/fix/landline/?view=landlinetroubleshooter
Just use this option highlighted.
It will do a line test, and may find the fault. Either way, just follow it through to request a visit
Message 16 of 20
Thanks Keith @Keith_Beddoe
Appointment made for this coming Friday. Appreciated.
Message 17 of 20
Openreach attended today and did some work including replacing the wall socket with the updated model that does away with the need for a filter.
About 4 hours later, we were called on my mobile. Being deaf, I passed the phone to my wife. It was Openreach engineer asking if our landline phone rings and suddenly it did!
He must have had two mobile phones to pull that one off! Nice guy, really friendly even from 2 metres away!
Message 18 of 20
Hi Carlusha, thanks for the update and good to hear the engineer has fixed things.
cheers
John
Message 19 of 20
And Openreach will never bother to investigate why the job wasn't done properly in the first place.
Message 20 of 20
Our OR operative did but I'm keeping the reason to myself. It was only a couple of days and, in any case, we never use our landline. I only wanted it connected as we pay for it to get broadband.
