Jak79
Newbie
Message 1 of 6
Phone says line busy
Hi.
My phone is saying line busy when I go to call someone !! I've tried calling my land line from my mobile but it just rings on my mobile but nothing on my land line , I've unplugged it taken batteries out etc....  but nothing
5 REPLIES 5
Message 2 of 6
Re: Phone says line busy
@Jak79
Who do you pay for your phone service?
Jak79
Newbie
Message 3 of 6
I'm with bt
Message 4 of 6
 If you can't make or receive call report phone fault to 151
Jak79
Newbie
Message 5 of 6
Great thanks, just wanted to see if anyone has had the same problem before calling.
Distinguished Guru
Message 6 of 6
I suggest you try a known working corded phone direct into the test point of your main phone socket. There could be a problem with your phone. This should prove one way or another.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
