UrbanGrunt
Expert
Message 1 of 2
Phone socket dead
At the beginning of January my FTTC faceplate got broken from a bad thunder storm, I fixed this by installing a ADSL microfilter and then replacing the faceplate with the updated version. Well once again the face plate has broke, I have no dial tone but my Internet is fine.
I would like some input on this, would you say its just bad luck and deal with it? Or is there something possibly going on to cause this?
The faceplate broke again after a bad thunder storm and very strong winds overnight.
1 REPLY 1
Message 2 of 2
Re: Phone socket dead
I would just stick to using the microfilter, as that is what BT are now supplying for Infinity self install. It seems to me that the full faceplate has too many sensitive components.
