PAP
Newbie
Message 1 of 2
Problem with BT8600 answering machine
Problem with BT8600 answering machine. After a caller leaving a message hangs up, it continues to record a tone (intermittent at first and then continous) for about 45 sec. Is it a setting? Is it a faulty unit?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Problem with BT8600 answering machine
Hi @PAP,
There may be an issue with your handset. Can you get in touch with the product helpdesk?
Their contact details are on the following page:
BT8600 Advanced Call Blocker
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
