Hi,
Here is some great info about BT's Protected Services Scheme
Cheers
Sean
 | Community Manager | SeanD |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the star next to a reply to say thanks | Help guide to using the community? Click below |
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You |
